best cooling
You can't really overclock that cpu anyway (Unless you have some LN2) as it is pretty much maxed out already.
I would say you need a high end air cooler (Noctua D15, Phanteks PH-TC14PE etc) or a 240mm/280mm AIO.
Have you already bought the cpu ?
Yes, it's running at between 30 and 40 when I'm using it lightly atm, but am worried if I start playing games
Here are a few good air coolers and some aio coolers.
You also have the Noctua D15/S and BeQuiet Dark Rock Pro 3 for more £££.
What case, motherboard and ram do you have ? As you will need to check for any potential fitting/clearance issues.
My basket at Overclockers UK:
Total: £445.99
(includes shipping: £11.10)
