Best Corsair for my board
14 Feb 2006
Hi all whats the best corsair for my motherboard an Asus A8N-SLi Premium nForce4 SLi .
Im getting a opty 146 and im currently running kingston value 1gb.
i want it to be fast and good for oc...
Thanks in advance.
will be running 146 with scythe ninja 120mm in push and shove config.
Money isnt a problem... just need to no whats best for me...
The new 3500ll's, (2x1GB) are using the latest Infineon Rev C chips and are supposed to be good. You'll be getting good timings with these IC's.
Yeh they are very good, quite pricey... but as you say, money is no problem:)
This is about the best I can get out of mine... Any higher on the HTT and I need to slacken the timings.
Awesome result mate. If the ICs used on these modules remain consistent accross different batches this RAM will be the best 2GB kit available. Only the Ballistix can match those timings at that speed but they tend to have a high mortality rate.
I've spoken to 2 others that can get similar timings at around the same sort of speed... So thats at least 3 sets that are good:)
And those timings are reached at 2.6V! Makes it even better... They were well worth the money in my opinion:)
