I have both A80 and Silent Loop 280mm A80 is Asetek OEM and their pumps make noise. My A80 pump makes significantly more noise than my Silent Loop 280mm pump .. and fans are quieter as well.
Here is link to testing of both A80 & Silent Loop 280 as well as Eisbaer 360 & 240 with Silent Loop being slightly cooler than A80, Eisbaer 360 falling between the two and Eisbaer 240 not performing as well. Ignore their air cooler comparisons because they are testing in a case using room ambient air temp as baseline, and air temp into air cooler inside of a case is always at least a few degrees warmer than air entering case into raidator, and can be as much as 20c warmer into air coolers. They list temps as K (Kelvin) but I think it is Celcius. 40,00K would be -233.15C or 40,00K is 3726.85C.
https://www.hardwareluxx.de/communi...mit-280-mm-radiator-im-vergleich-1147070.html
I don't know how they got such a difference.differences in temps are within error margins
this one shows major differences between the silent loop and the bog standard A40
https://www.eteknix.com/be-quiet-silent-loop-280mm-aio-cpu-cooler-review/5/
given that people run computers in cases it is a pretty valid comparison even only for that case.
Both are 280mm radiators and only a few dB difference in noise levels. Silent loop waterblock is easily as good, pump is better and copper versus aluminium so common sense says performance should be similar not an aluminum radiator with less flow rate pump testing significantly better.
We need to use our brains instead of blindly believing test data.![]()
Assuming you are asking about CPU temps and noise levels, most review sites list a bunch of coolers. Problem is as above, their testing is done to such un-scientific / non-laboratory standards that it is extremely hard to compare cooler performance with their results.Is there any graph that shows a list of many coolers in 1?
