Best cpu air cooler for Conroe
26 Dec 2002
Hi
I've got a Conroe 6600 & looking to upgrade from Stock HSF, this will be mounted onto a GigaByte DQ6 Motherboard.
It has to be not so loud, but good for overclocking. I was thinking to buy one of the following:
Arctic Cooling Freezer 7 Pro CPU Cooler (Socket 775) (HS-017-AR) @£21.14
Scythe Infinity Heatpipe CPU Cooler (Socket 478, 775, AM2, 754, 939, 940) (HS-006-SY) @ £38.76
or
Scythe Ninja Plus Rev.B Heatpipe CPU Cooler (478/754/939/940/AM2/LGA755) (HS-003-SY) @ £35.24
Your opinions please.
ta.
Hold on - Doesn't the DQ6 have some sort of copper plate underneath the CPU..?
....So this could cause a problem - If you need to fit a cooler that requires a backplate etc...
