Thanks that was useful. Do you have a view of the Radeon 7900XT? I do not know much about radeon cards.In a year, who knows, but right now, if you have a budget of around 2K then the easy option would be something like:
- 5700X3D & 4070 Ti Super (keep motherboard and everything else, expect to pay £1K)
The less price conscious option:
- 7800X3D & 4080 Super (i.e. nearly a new PC that'll eat your whole budget)
Similar to 4070 Ti Super unless you enable ray tracing and decent value (relatively) if you get one around £600.Thanks that was useful. Do you have a view of the Radeon 7900XT? I do not know much about radeon cards.
As you helped me a load with my build Tetras, on this very exact subject I'm guessing I'm good with my new build and this monitor size? I'm getting one delivered tomorrow so my hope is I should be fine? (Apologies for the slight hijack!)In a year, who knows, but right now, if you have a budget of around 2K then the easy option would be something like:
1440p? Sure, no problem for a 4080.As you helped me a load with my build Tetras, on this very exact subject I'm guessing I'm good with my new build and this monitor size? I'm getting one delivered tomorrow so my hope is I should be fine? (Apologies for the slight hijack!)
There's no universe I recommend a GT 1030Can't believe he pushed me towards the GT1030 instead of 6700xt though.
I think I said non-X, I recommend the X very rarely.Shout out to Tetras from me as well. (Should've took your advice and went for the 5600X)
Cheers, looking forward to the AW3423DWF arriving !!!!1440p? Sure, no problem for a 4080.
Enjoy sir. But can't they come up with more inviting names than that lol. 'What screen do you have?' 'Ive got an AW3423DWF!'Cheers, looking forward to the AW3423DWF arriving !!!!
In all seriousness, enjoy your system,it looks really powerful.I struggle with it to be fair, Im only 87% sure I haven't bought a number plate
