Which one will fit? Any?
Also is there any CPU I can upgrade it to or anymore than 2gb of ram?
if cash is short look on auction sites for elitebooks which are dirt cheap 2nd hand.
I only want laptop to run mpps and vagcom for vag cars
yes.. but you cant polish a turd. an Atom makes a Celeron look good and that's saying something. an SSD will certainly improve any laptop. I have one on a Core2Duo and it flys. and add the extra 1gb of ram. its a standard 2.5" drive and is located under the keyboard..
I still think your wasting your money, however.. you can always put the SSD in another laptop later if you decide
Any ideas of a really small laptop around £100 that's better ?
Serial port? Sorry could you explainDid you even look at the Dell E4310 I suggested? £87.50 on the Auction site at the minute. £99 gets you one with 4GB ram and a bigger hard drive.
Will run rings around an atom netbook. If you need a serial port for vagcom etc then you can buy a port replicator that has one.
And there over 110 on eBay![]()
Don't really like the design reviews they there screen hinges are flimsy but I guess if it's best for price I'll have to get it . Thanks for info
