Best DDR2 Choice
23 May 2008
I have a choice between:
Corsair XMS2 Dominator TWIN2X4096-8500C5DF Matched Pairs 4GB Kit (2x2GB) PC8500 DDR2-1066 CL 5-5-5-15 240-pin Dual Channel DHX Memory w/ Fan
and
Corsair XMS2 TWIN2X4096-6400C5DHX Matched Pairs 4GB Kit (2x2GB) PC6400 DDR2-800 CL 5-5-5-18 240-pin Dual Channel DHX Memory
for about same price,
to be fitted onto a Gigabyte GA-P35-DS3L with a Q6600, maybe OC'd to 3GHz.
Which memory sticks would be better?
Thanks
Short answer: What Cob said.
Long answer: With a Q6600 PC2-6400 gives you 3.6 Ghz (9 x 400) and PC2-8500 just under 4.8 Ghz (9 x 533).
So, if they are both the same price, you might as well get the faster sticks (which if nothing else may carry a higher re-sale value in the future, one which is significant for 1333 FSB CPU clockers as they have a realistic use for it).
Thanks for the reply.
What about:
Corsair XMS2 DHX TWIN2X4096-6400C5DHX 4GB DDR2 2X2GB PC2-6400 DDR2-800 CL 5-5-5-18 240PIN Memory Kit
vs
Corsair XMS2 DHX TWIN2X4096-6400C4DHX 4GB DDR2 2X2GB PC2-6400 DDR2-800 CL 4-4-4-12 240PIN Memory Kit
the only difference that i can see are the timings, prices are the same.
I understand the 6400's are the best for Q6600 OC'ing as they love the FSB.
** Memory is very very confusing!! Where can I go read more about this stuff? I read the stickies but i'm just blown out of my mind **
The latter out of those two since 4-4-4-12 is in theory 20% faster than 5-5-5-18.
But out of the three pairs I would still go for the first one listed in the first post if they're all about the same price.
Equivalent speed and timings are pretty easy to work out. Memory can afford to drop a timing (eg- 4-4-4-x to 5-5-5-x) every 200mhz or so. So in theory 800mhz 4-4-4-x would be about the same speed as 1000mhz 5-5-5-x. So 1066mhz 5-5-5-x (PC2-8500) will be a little faster than 800mhz 4-4-4-x (PC2-6400).
That's a bit too simplified, but you get the jist.
