Best ddr3 for Asus Maximus Gene V
18 Jun 2005
Hi,
I am about to buy 2X8GB ddr3 for a new build which will be an Asus Maximus Gene V and 3770K. I'm trying to stick with red/black dimms to match the theme of my case. Probably cooling with a megahalems red or h80i. So am seeking some advice.
I was wondering what would be the best kit to get from the ones I have listed below. Also is it safe to run at 1.65v.
It would seem the only 1.5v memory is the 1866mhz CAS9 and 2133mhz CAS11. The only exception being the 2400mhz Geil Evo CAS11, which I assume could be tightened up at lower speeds.
All the Team stuff 2400mhz stuff is 1.65v CAS10.
Which is the best kit ?
1866mhz, 1.5v, CAS9
Corsair Dominator PLATINUM 16GB (2x8GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit with DHX Pro Connector (CMD16GX3M2A1866C9)
http://www.overclockers.co.uk/showproduct.php?prodid=MY-351-CS&groupid=701&catid=8&subcat=1387
GeIL EVO Veloce Hot-Rod Red 16GB (2x8GB) DDR3 PC3-14900C9 1866MHz Dual Channel Memory Kit (GEV316GB1866C9DC)
http://www.overclockers.co.uk/showproduct.php?prodid=MY-166-GL&groupid=701&catid=8&subcat=1387
2400 mhz, 1.5v, CAS11
GeIL EVO Veloce Hot-Rod Red 16GB (2x8GB) DDR3 PC3-19200C11 2400MHz Dual Channel Kit (GEV316GB2400C11ADC)
http://www.overclockers.co.uk/showproduct.php?prodid=MY-150-GL&groupid=701&catid=8&subcat=1387
2400 mhz, 1.65v, CAS10
TeamGroup Xtreem LV 16GB (2x8GB) DDR3 PC3-19200C10 2400MHz Dual Channel Kit (TXD316G2400HC10QDC-L)
http://www.overclockers.co.uk/showproduct.php?prodid=MY-011-TG&groupid=701&catid=8&subcat=1387
2133mhz, 1.5v, CAS11
TeamGroup Xtreem LV 16GB (2x8GB) DDR3 PC3-17000C11 2133MHz Dual Channel Kit (TXD316G2133HC11DC-L)
http://www.overclockers.co.uk/showproduct.php?prodid=MY-015-TG&groupid=701&catid=8&subcat=1387
GeIL EVO Veloce Hot-Rod Red 16GB (2x8GB) DDR3 PC3-17000C11 2133MHz Dual Channel Kit (GEV316GB2133C11DC)
http://www.overclockers.co.uk/showproduct.php?prodid=MY-148-GL&groupid=701&catid=8&subcat=1387
If it was me I would buy the Team 2400 C10. This should tune well at all frequency's. I personally use Team Xtreem in two X79 rigs with great effect.
Thanks mate for the quick reply. Much appreciated.
One question on the Team 2400 C10.
Is 1.65v safe and will it run at 1.5v on lower speeds (like the 2133kit which is 1.5v)
thanks
edit : doh.....you already said it will tune well at all frequencies....
