Best DDR5 Memory to pair with an Intel i7 12700k?
27 Dec 2004
Staffordshire
Hi,
I've managed to get my hands on an i7 12700k CPU and MSI PRP Z790-P Motherboard.
Would someone more clued up than I be able to recommend a well matched set of 32gb memory for the CPU in terms of frequency and CL etc?
Thanks in advance,
Russ
Hi,
Thanks in advance,
Russ
genuinely get 6000mhz+ and any CL.
ive seen a few reviews lately as ive just been looking and TBF as long as your not hitting 4800Mhz its all just same same.
6000Mhz cl30 is best in my eyes, but if you budget is good for it the higher the better but the difference is a few FPS in game so you budget is what matters.
32GB 6000/cl30 can be had for £100 anything thing up is only minimal difference and the cost difference is not really minimal
Thank you for taking the time to reply.
I was doing some research yesterday myself and reached a similar conclusion to yourself. Ive seen the following memory which I think might be a good pairing:
6400MHz and a CL of 32
