- 24 Nov 2003
- Manchester
As per title, anyone seen any decent deals for the 8800?
Would prefer a 12 month contract.
Haly said:If you don't mind a clearance phone then http://www.e2save.co.uk/mobile/phon...CL&PHPSESSID=5febea50df3fc0f239f8e01b0d18c802 might be good for you![]()
Haly said:Not had a problem with cashback personally, and ordered a w810i from there the other day and it arrived the next morningBut your call, was just a suggestion.
disfunktion said:Was the one you ordered clearance? - I think non-clearance are always shipped right away as they are sold at full price on higher tariffs.
I was just looking for the cheapest way of getting the phone - which is £270 for the link you posted above. But if all i'll be getting is the phone and the charger then it wont hold its resale value so it would be pointless getting it.
gib786 said:£270 will easily buy you a boxed one in good condition on ebay, might even be able to get a black one with a bit more cash
disfunktion said:lol, £400 is a bit more than what i want to spend!
are the housings easy to change?
