I have both the Raspberry Pi 2 and a Fire Stick. Both run Kodi/XBMC fine, no issues with either.
Main advantage of the Fire Stick is the built in wifi and included remote (there is also an app which is good)
The Raspberry Pi 2 is slightly quicker and of course has ethernet and built in usb ports for playing local media. But Kodi/XBMC is very similar on both. Just have to decide if you want the built in wifi or ethernet and usb ports.
Thanks for the reply. Currently the wifi I have in my house is terrible and the router is ancient too. USB I haven't thought too much about as my blu ray and tv's have ports. But I can see the advantage with the pi.
I was looking at Android tv i was looking to replace one of our tv's in our bedroom with a smart tv. We have WDLIVE TV. But it lags and is quite slow so was thinking getting another tv without the smart features or 3D and getting one of them android boxes
It's probably what you mean but if I were you I'd definitely go for the Pi2 - I had OpenElec on the first Pi and the UI was painfully slow - the Pi2 should be loads better! (although playback was fine and so if you use a smartphone app such as Yatse rather than browsing on screen, the first Pi will probably do the job OK!)
