Best dual-chamber mini ITX case?
6 Jan 2006
Ayy
Any recommendations?
I've seen the Corsair Carbide 240, but that supports MATX as well, ideally want it specifically for ITX so its as small as possible.
Needs to be able to fit an MSI R9 380 4GB as its quite a chunky card especially with the back plate, and I would like the option to fit an H80i in there at some point.
The 250D isn't dual chamber, it's a nightmare for sorting out wiring. I spent an hour and a half trying to sort the wiring in my sons new build, there's nowhere to hide any of it. The best you can do is zip tie as much as possible out of the way so that the air flow isn't affected too much. I don't know if a 390 would fit.
I've got the Carbide 240 and it's a brilliant case, yes it's bigger but not that much bigger than the 250D but being dual chamber all the cabling is hidden away and it's got lots of space for fans or a radiator.
