I want to buy some dual screen arms for my setup,
at the moment I have two screens mouted with wall vesa mounts, while it works well, it's difficult to get the screens to align properly (mounts are not height adjustable). So I'd like to sue a better method do this.
No bearing in mind I have a 18mm MDF desk, I'd like to get a clamp type that sticks onto the desk, is the desk suitable?
I know MDF isn't OAK, but the stuff I have seems to be tough enough I can rest my whole upper body weight on on hand size spot, and seems to support it fine.
I'd like a 2 arm rig that can stand the test of time, won't bend or give way after a few months, and will function like new 10 years down the line.
Are there any ones you guys can recommened at all. Price is an issue, I wouldn't want to spend more than 100 quid on it.. But if you have to recommened more expensive ones I can stretch the budget to meet the requirements.
