Best dvd menu maker software
Ish
Ish
11 Jan 2006
West Midlands
Hi
what software should i be looking to use to create the best most professional looking dvd menus?
Thanks
If you mean the DVD itself then Ulead DVD Moviefactory does a good job.
I don't bother with menus and just use WINAVI.
I have used ConvertXToDVD for a couple of simple menus.
If you mean making cover artwork then I always use Corel Draw.
