Simple question...
If you had £100 to upgrade your CPU from a Pentium Dual-Core E5200 running @ 3.7GHz, which current processor would give you the best bang for your buck? Basic Windows 7 tasks and gaming would be the main uses, and let's ASSUME that socket type/CPU compatibility is not an issue so can be Intel or AMD.
Cheers, just looking for ideas at this early stage
