Just purchased the following electric shaver:
Braun 8995 360 Complete Shaver
£99.99 delivered.
Product Features
The 360 Complete is one of Braun's highest spec shavers
Evolution from the previous Activator range.
EDIT (10/07/2008) Its now cheaper at the catalog high street store: £95
They must have read my post
Power Comb lifts hairs that lie flat to avoid missed hairs.
New precision blades cuts hair close in a single stroke for closeness and comfort
Smart Foil uses a unique hole pattern to capture hair at different angles
Active head uses micro oscillations to enhance comfort and smoother gliding
Contour hugging head automatically adjusts with every facial contour
Clean and Renew system provides total daily shaver maintenace (manual cleaning still possible if you choose)
Cleans the shaver head in alcohol for optimal hygiene and less irritation on the skin
Selects the best program based on how much cleaning your shaver needs
Cleaning formula also lubricates the blades for optimal cutting performance
Totally dries the shaver head at the end of the cleaning cycle
Shaver battery is automatically charged while seated in clean and charge system
LCD display provides information on battery capacity and cleaning status
Mains and Rechargeable from auto 110-240V for worldwide use
1 hour charge for upto 50 minutes shaving time
Automatic battery care using Braun SmartLogic charging system
Includes 1 cleaning refill (30 cycles), hard travel case and cleaning brush
MY OPINION:
First of all becareful as a certain high street catalog store charge £180 for this which is £80 more than i piad for from
http://www.shavers.co.uk/ (£99.99 delivered)
The important thing for me Is that Its KIND to my neck
Cuts a lot better than my old razer (braun 4 years old).
looks bloody loverly on my shelf
(see pic above)
the clean an renew system takes 30 mins and a little noisey so if its in your bedroom best not have it cleaning itself while trying to sleep
If like me you dont wish to spend 30+ minutes shaving and beeing ripped off with blades £££££ I recommend this shaver.
I also recommend the company I used. very quick delivery which is free.
