i like the one i have, nzxt sentry 2.
its a touch screen controller for 5 fans, and each one has both a 3 pin and 4 pin molex connector, so you can use either
I really like my Scythe Kaze Master Ace. It is a great controller that supports up to 4 fans and 4 temperature probes (not that I use the probes). You can turn off the fans from this controller and the LED display is clear and easy to read giving an RPM readout and temp readouts. It supports both three and four pin fans and with cheap 3 pin to molex convertors molex fans too ;D
Thanks guys. I've got the Akasa Apache Fans with 4 pin header but my mobo only has 3 pin headers. I'll check your recommendations and appreciate your responses.
