Mine has been very quiet (and very hot). GPU-Z said it was at 40% fan speed, but XpertTool says 27% (haven't touched the settings yet).
Using XT I whacked it up to 50% just to check, it's probably bearable with headphones. It's idling at 38C now, what do you reckon is the best "sweet spot" for noise levels? Seems like 35-40% might be alright for constant use. I'm gonna try that anyway when I get round to doing the Rivatuner guide.
btw, 100% sounds like it'd suck my fillings out if I got close
