Best Fan setup for my case
8 Jan 2007
Essex, Canvey Island
I have an Antec 300 & 4 Akasa AK-FN058 Apache Black Super Silent 120mm Fans.
The PSU is at the bottom of my case, I have 2 Fan slots at the front of my case which I believe should be intake and then I have 2 on my H60 Corsair. I just want some clarification on what would be the best setup since there is a lot of opinions regarding the most suitable. There is also a 200MM air vent at the top of the case where there was normally a fan but I removed it since it was too loud.
So to the skim readers:
Which way do I want my H60 x2 Fans blowing (Considering 200MM at top and back exhaust)
Where do I want my intake and exhaust?
I was thinking having both CPU fans blowing into the direction of the case and having the 2 at the front blowing out?
Have the two fans for the H60 on either side of the radiator in a Push/Pull configuration with them both blowing out the case at the rear.
So air comes in the front, some goes in the psu and out.
Some goes through the radiator and out the back.
