Best fans?
17 Jan 2005
Liverpool
What make of fans are generally considered the best?
Ive got a 92mm YS Tech on my CPU at the moment but its starting to sound a bit dodgy, was thinking of replacing it and want to know which makes are the best:) Have heard good things about panaflo and nexus?
Cheers!
Akasa ambers are probably the best for noise / air pushing ratio - the nexus is slightly (and I mean slightly) quieter but pushes a fair bit less air. The ambers are also cheaper.
I've not used panaflo but I too have heard good things. I've asked ocuk to get nexus and panaflo stocked, but they're not listening! :p
edit: oops. Meant ot say it depends if you want silence (nexus, ambers) or air pushing (deltas, any others) but I personally a a strong believer in silent pcs!
kinda depends, what HSF you got? Cause a lot of fans with a high CFM don't perform as well as you'd like, as they have a dead spot in the middle where you want the most cooling.
I keep looking at all these 'novelty' fans from Thermaltake and Coolermaster etc. But most of them don't seem to live upto their billing
