Best Favicon Creator
Permabanned
21 Apr 2004
Wolverhampton
What's the best Favicon creator?
Needs to be:
  • Free
  • Saves 16x16 and 32x32 versions
  • Easy to use
Cheeeeeeeeers.
MS Paint + Irfanview (free). Create the icon in MS Paint at whatever size, save as BMP them open with Irfanview and save as *.ico, you can even choose the transparency colour in Irfanview.
iCraig said:
Does that support 16x16 and 32x32 resolutions, or does it just save one size as a .ICO?
It doesn't mater, it depends on what size you made the image at, if it's 16x16 pixel image it will save as 16x16 resolution. You can get programs that scale your image to 16x16 or 32x32 but it's no different than shrinking it manually before saving. Basically it's no different to JPG or BMP, your icon will be whatever resolution you save it at.
