Best Flat LG 4k OLED?
6 Jun 2005
Plymouth / Cambridge
Hi,
i might be in a position to buy a new monitor soon and i am thinking of getting a LG 32" 4k OLED monitor for work and play. i was thinking of maybe the
32GS95UV-W or 32GS95UV-B the dual if they dropped in price in the near future. Not looking for the cutting edge but around £600 - £700 mark.
big fan of LG so would prefer staying with LG, not looking to game at 4k, i've just bought a 5070ti (cos of price rises) so i don't think it would cut it for 4k, but would prefer it for work at that res.
Does anyone have either of these and would you recommend them? Any others i should consider?
thx
P
The AOC AG326UD seems a decent option for the price and has the same panel as the more expensive GIGABYTE MO32U
Mite be worth a look.
Well I would highly recommend the MSI MPG 321 URX I have, one of the main things with the LG displays is that they use W-OLED panels rather than QD-OLED so really it's a question of which one you want as they do have some differences, worth looking into I think.
