i just brought a WC setup off the MM, and i was wondering what is the best fluid to use to test the setup with without damaging it. the fluid will be thrown away after as i helped a friend purchase it and he will be taking it home on the train.
this will be the first WC me or my friend has put together so testing will be important as we have no idea how to put it together
WC kit
1) Swiftech mag-drive pump
2) Dual bay res, dangerden i think
3) XSPC 120.2 rad
4) Swiftech Apogee GT block 775 + other fittings
5) 10+ metal barbs
6) T-Line
7) Some tubing (tygon of some sort i think)
8) some spare fans i have ( 2 bright blue ones are botched together to one molex ) and others
i have no fluids specifically designed for WC at home or at my friends
WC kit
3) XSPC 120.2 rad
5) 10+ metal barbs
6) T-Line
