Best for performance? Mhz or timings?
8 Jun 2006
Hertfordshire
Hi guys
I have just got my Ballistix 5300 kit back from RMA, I have 4 sticks in and I'd like to know should I stick it on 800mhz 3-3-3-9 IF I can get that, or loose timings and 1000mhz IF I can get it stable?
Sorry if this is a n00b question but I'm not to sure either way :(
Different applications benefit from one or the other. Imo its usually best to find a good middle ground that way you have all bases covered. So lets say 800@3-3-3-8 or 1000@5-5-5-15. I would go with 900@4-4-4-12. If you catch my meaning;).
There's probably not a lot in it. Give each setting a quick superpi run and take the best.
C2D seems to like higher Mhz at the expense of tight timings usually.
Superpi it is then, running 4-4-4-12 @ 890 at the moment and seems good!
Lol ok at what 16K 64k?
Also what score am I concentrating on? Thought I'd used this app before but I haven't :(
Cheers
Hi Cob
So my score on 1m is 18 seconds is that correct?
