best for ps3
6 Jan 2009
Hertfordshire
Im after a blue tooth keyboard for the ps3 and i was wondering which would be best to go for?
Don't really have a budget but wouldn't be using it that often so don't want to spend too much on it.
any help appreciated thanks
I have a Keysonic 595BT, its a nice little thing (about the size of a webbook keyboard), and works perfectly with the ps3.
I think a lot of peopel will reccomend the official one which clips onto the controller.
For handyness the official clip on pad is indeed excellent, bit fiddly though so can do occasional typos etc, nothing to worry about if you're just sending people a quick message.
If you plan on using it for typing on forums etc i would recommend the keysonic one above, tried it once and it was pretty good.
Nah just want one to type the occ message to people
No where seems to have stock though ... oh well ill keep my eyes peeled
