Best for under £450
HERE
It's about budget, depending on OS, but for that price, this is about the best you can get whilst being made for you. And this will run Crysis and Arma 2, but nnot excellent.
Just look about for videos or benchmarks with the 4850. Its a good GPU for its price.
Yes, it has a faster clock speed than the Intel one I sent.
That one will run abit faster and can run Crysis and Arma 2, but if you want higher quality on the games, and better FPS, you have to up the budget. But once you have a PC, you can always upgrade later :)
And could even add a second 4850 in crossfire or a 5850 later :)
HERE
+1 thats pretty much the best you will do for a pre-build (this will be a bit faster due to the X2 245, but it may put the OP over budget). With the OS (I suggest going for windows 7) it will take it to pretty much bang on your budget.
I agree that either of these machines will play crysis, but not amazingly.
I'm looking at the "Nero" mainly because it's going to be my first desktop and I'm looking into buying upgrades when I have enough money.
P.S. I've found Windows 7 for £69.99 so that will save me a few pounds :D
My build is an i5, and I won't be able to play games for 2 months after as I have to save cash after in the build. So i may try GTA IV with a 6200GS :)
But I'll be putting a 4890 in it. Or a 5850 :)
what do you mean you won't be able to play games for another 2 months?
