Best Full Tower Case Under £150
14 Sep 2014
Northern Ireland
Hi, i am looking into buying a full tower case and was just wondering what would be a good choice. I want one with good air flow, maybe a few fans and capable for watercooling. Unfortunately, i do have a budget of around £100-150, but obviously the lower the better. Any suggestions?
I have picked a few:
Competitor links.
Thanks
Really like my 780t masses of space to work in it makes my components look small inside even with two r9 29 0 installed. Has a basic fan controller built in too that currently controlling 5 fans if I remember correctly
http://www.overclockers.co.uk/showproduct.php?prodid=CA-220-AN&groupid=2362&catid=160
or
http://www.overclockers.co.uk/showproduct.php?prodid=CA-215-AN&groupid=2362&catid=160
£139.99 inc VAT.
Stock is landing next week.
Here is what I did with one.
Any of the Phanteks cases mate, I'm using both the Primo, and the Luxe, and are both great. Loads of room to work with, and plenty of unique little features. The build quality, and CS are also great.
