this seems to be a strong option at the moment
ACER Predator Helios Neo 16 AI 16" Gaming Laptop - Intel® Core™ Ultra 9, RTX 5070 Ti, 1 TB SSD
That’s really helpful thank youSAME PRICE with 2tb m2 .
MSI Vector 17 HX AI A2XWHG-003UK, 17" QHD+ 240Hz, Intel Ultra Core 9 275HX , Nvidia GeForce RTX 5070 Ti GDDR7 12GB, 2TB NVMe PCIe SSD, 32GB DDR5,
Your welcome.That’s really helpful thank you
Your welcome.
Please check the specs between the 2 just in case I missed something and check out reviews.
Good luck.
Can you get a legion 5 pro with a 5070ti thought the max for the 5 was a 5070, legion 7 has the ti but the oled would be nice?you can also get the legion 5 pro with similar specs to those laptops above with an OLED screen for £2070 (even cheaper if you have perks at work or some student discount)
the legions are generally highly regarded. neither the acer or msi would have a OLED screen.
ah yes on Lenovo's website you can find these but only with the 5070 - not the tiCan you get a legion 5 pro with a 5070ti thought the max for the 5 was a 5070, legion 7 has the ti but the oled would be nice?
wrong the 5pro also comes with the 5070ti - i just checked now on the uk site.pretty sure the legio
R u talking about this Legion Pro 5i 16 (Ultra 9-Windows 11 Home-32GB-1TB-RTX 5070Ti)wrong the 5pro also comes with the 5070ti - i just checked now on the uk site.
Fair point83LUCTO1WWGB1 is £2,100 and includes the 5070Ti. In fact given the relative price difference vs the much weaker 5070 equipped model it makes the latter pointless (unless its put on sale at a significant discount).
