Best gaming mat?
Razer exactmat, or should I say Razer Vespula >.>
my reason being that they have got two sides, 'control' and 'speed' and that they have good reveiws..otherwise I would definetely purchase a Boogie bug XXL.
Boogie bug, i have the standard one which is very good. But i think ill purchase an xl. We all know that bigger is better.;)
Get a steelseries QcK mat of any kind if you like a soft mat, or an HD series from steel series if you like a hard mat. Nothing beats SS's mats.
I have both the boogie bug xl and the roccat taito. Both are excellent pads and feel very similar, main difference is the size. I'd recommend either.
Thanks for the advice. Finally got a Roccat Alumic. Just fed up with mouse mats curling up and getting grubby!
For info it is expensive but a great product.
Matt
Nothing really. Although a gaming pad is generally designed to give the mouse a smooth fast travel. Now all mice are optical some surfaces on the pad are different giving better responses.
Matt
