Best Gaming mouse and keyboard
13 Nov 2008
What is the current best gaming mouse for online games and serious action games like crysis etc...
I currently have the Logitech G500 and have loved it for years but now it has started randomly disconnecting from my computer (doggy wiring i assume)
So in the market for a new Gaming Mouse and while we are at it, what is the best gaming keyboard? mechanical? Razer?
Thanks Chaps
Honestly its very difficult advising on keyboard/mouse as its down to individuals choice. I've tried some mice that I just couldn't use due the the fit, and the same for keyboards (keyboards for me mean no low profile keys and no extra keys to the left of the keyboard due to where I rest my hand).
If its possible (it usually isn't :( ) try and get your hands on a few first.
Failing that take a chance and have a look through the various reviews and make a best guess on what you think will be right for you.
edit: my setup is a roccat kone mouse and a £5 keyboard :)
Thanks Chaps
No real 'best'. A bunch of good stuff, though.
QPad MK-85.
Corsair K95.
Razer BlackWidow Ultimate.
Gigabyte Osmium.
(MX Brown or MX Black for me).
Mouse :
Corsair M60.
SteelSeries Sensei / Raw.
Razer DeathAdder.
well, loads of choices really... Lots of good mice, depends what sort you prefer. Number of buttons, size and weight, palm grip or claw grip...
For me the best mouse currently is the Razer Naga Epic http://www.overclockers.co.uk/showproduct.php?prodid=KB-059-RA&groupid=702&catid=23&subcat=1276
Best feature set and wireless makes it theoretically the best mouse currently available. I've had wireless gaming mice (currently use a rat 9) and I've never experienced any lag issues. There is the battery swapping/recharging to do but the mice usually have a onscreen warning or a warning light on the mouse itself so you shouldn't be caught short in a game unless you're really stupid.
Keyboard? Just get the one that feels best to you but you should probably get a mechanical if you're a serious gamer. If you can type fluidly then that's all you need from a keyboard.
I would never buy a Razer mouse again, had three and all fell to bits within 18 months, overpriced.
And on the flipside I#ve had 3 that never had a single problem :D
I'm using the Razer Deathadder + Razer Blackwidow Ultimate.
I would highly recommend the Deathadder. The Blackwidow is too expensive for the alternatives that are now available.
I would go for the Gigabyte Osmium and a Razer Deathadder
Have a Zowie AM mouse on the way to replace an aging Microsoft/Razor Habu! Mice are a very personal thing, but will report back with my own thoughts. I find people don't attach enough importance to their choice of mouse - it's one of the key interfaces between you and your PC! Don't just go on recommendations, research what suits you. Everyone has varying preferences.
Here are some tips you might find useful for choosing a mouse:-
- Do you us a claw or palm grip? Some mice are designed for a specific grip type.
- Do you have big or small hands? If you have big clubs, you'll probably want a mouse with a larger shell.
- Lefty or righty?
- Do your palms sweat? A rubber coated shell is better for sweaters, otherwise you might prefer a glossy shell.
- Do you lift your mouse your while gaming? If so an optical might be more suitable, as laser sensors usually have a higher lift off, causing the cursor to briefly do it's own thing while the mouse is in the air. Lasers track on any surface. Opticals need a mat, preferably uniform in colour.
- What kind of games do you play? fps/rts etc. Some mice are purpose built for specific types. Pay attention to whether the mouse has built in acceleration or prediction, and whether it can be turned off (on many models you can't).
- Wireless/wired. Do you need to feed it batteries? Some (not all) wireless mouse have high lag, so wired is more suitable for gaming.
- What DPI do you currently use? You're unlikely to need more unless you know for certain that your current mouse needs need higher sensitivity. Very high monitor resolutions are a factor - you might want at least a 1600 DPI model for 1440p gaming. Again, this is a personal thing, people have wildly different preferences.
- Would you prefer a driverless mouse? Very useful for LANs, and automatically avoids problems with software. On the flip-side you may want access to all the configuration options in one place.
- Do you care for lights/decoration?
- Do you like lots of buttons on your mouse?
- Would you like a mouse with adjustable weights?
- Does the mouse support high polling (500/1000hz)? It reduces lag between your movement and your game. Again, this is a personal preference.
- Are you sensitive to stiff/loose buttons/wheel? Research the type of switches the mouse uses (Omron vs Huano for instance), some are stiffer/looser than others.
- Try to find out if the sensor is located in the middle/front/back of the mouse base. This seems to be a personal preference, probably depends on what your used to.
- Research specific models for driver/firmware issues, or incompatibility with other hardware.
- Find out about warrenty and RMA process.
Some suggestions in no particular order:-
Steelseries Raw
Razor Deathadder Respawn (not heard much about the new 2013 model)
Zowie AM
Logitech G400/G500
