Wedge said:I can highly reccommend the `Hyundai ImageQuest L90D+ 19" LCD Monitor` http://www.overclockers.co.uk/acatalog/lcd19.html which is slightly cheaper, 8ms response with i have found to be great for games, i mostly play FPS (Quake 3 Arena still my favorite) im sure it uses the same sreen as some of the Samsungs (Baddass will know![]()
it's using the 8ms Samsung TN Film panel as used in loads of other models like the Samsung 913B, Samsung 913B, Samsung 940B, Hyundai B90A, B91A. It's certainly a very well established and widely used panel. It's also the same panel that has been used in the already mentioned Samsung 930BF and 960BF, just with some more aggressive overdrive control applied to the operation of the panel. This inly effects responsiveness of the screen, fundamentally the panel remains the same
Still hogging all the armour and weapons?
Hope you're doing ok - I'm looking for a new monitor atm too, but waiting on the Dell 2407 as I fancy summit a big bigger...
Longpot said:Allright son!!! You wanna bit of paper with that?!?!Still hogging all the armour and weapons?
Long time no seeHope you're doing ok - I'm looking for a new monitor atm too, but waiting on the Dell 2407 as I fancy summit a big bigger...
Speak soon dood![]()
you still play?
