Best gaming wireless keyboard/mouse combo for £70?
im assuming your playing fps's but if not ignore me, if yous gaming you want to have a wired mouse, keyboard is doesnt matter. but if you have to use a wirless mouse then the logitech G7 is prolly the best one. Even the mx1000 isnt good enough to play a fps without it not being able to keep up..
Yeah, mostly FPS games mate. If I go wired then I'm pretty sure what I'll go for. I thought wireless would be the way to go next but don't you recommend them for gaming?
If your into FPS then stay away from wireless, I've tried several combos and had keyboard and mouse lag.
If it helps i've found the Saitek Eclipse and MX518 perfect for my gaming needs and as a bonus they look good to :)
