If it's Minecraft Java Edition then I'd look at nVidia cards.
AMD's OGL drivers under Windows are pretty poor and so their cards will get outperformed by a nVidia card a tier or two lower.
Or running AMD under Linux is the other option as they perform much better there than under Windows.
Their is a test driver floating around that is meant to improve AMD's OGL perf by a lot but not seen much testing of this outside of benchmarks and no idea when/if it'll release.
Also don't know if it'll work ok with things like optifine, lithium etc.
Well, should still perform well, I think the laptop 3050 Ti is around 1060 performance anyway depending on power/thermal limits.
