Best GPU for up to MAX £250
It's over budget but I'd get this one instead, find the extra £20.
YOUR BASKET
1 x MSI HD 7950 Twin Frozr III Boost Edition 3072MB GDDR5 PCI-Express Graphics Card with Crysis 3 & Bioshock PC Games £259.99
Total : £270.79 (includes shipping : £9.00).
Wouldn't go with that one!
Get the Gigabyte. Better cooling & UK RMA.
If you don't mind Grade-B products, this would fall under budget.
http://www.overclockers.co.uk/showproduct.php?prodid=BG-024-HS&groupid=595&catid=683&subcat=
I would say buyer beware for the 7870XT (Sapphire). Mine had really bad coil whine, but i guess that was just some bad luck, it seemed to run very well though, and its believed to be close to a 7950 with a good overclock.
