Best Graphics Card for £150-£180
i'd go with a 4870, slightly over as its £189 if you can afford it, if not go for a 4850, available under you're lowest budget.
4850 for that budget, should do fine on a 22" monitor. If you can stretch it slightly, then go for a 4870. The 9800gtx+ is a good card, similar to the 4850, but prices seem to have went up, the 4850 can be had for less.
Yeah I've decided to go with a 4850, I can always upgrade later down the line. Now I just need to decide which one of the 6 or so 4850's on Ocuk I should get lol. Any suggestions?
Thanks for all the help!
I decided to pay a bit extra and go for the HIS one with the IceQ cooler, rather than the standard ones with a stock cooler.
Why? Well from what I've read so far the extra performance you can get out of is worth the little extra you pay.
