best graphics card I can get?
14 Jan 2010
does anyone know what is the best graphic card i can get for my PC if
- money isnt too much of a problem (just nothing stupid)
- my PC is currently is lian li PC-q07, but im moving it into a lian li PC-Q11, so length is a serious issue
- my PSU is a corsair HX450
- other specs include:
2x 128GB M4
1x 1TB samsung F3
DFi lanparty p55-t36 MB
i7 860@stock
my current graphics card is a 5750 1GB
Hi there,
The PC-Q11 seems to be able to accept graphics cards up to 240mm (9.44 inches) while the Q07 can only fit one up to 180mm (7 inches) long. Therefore, I would recommend you upgrade your graphics card after you change your case to the larger one, as you will have more graphics card choice.
As for the PSU, that unit can deliver up to 33A on the 12V rail (which means a maximum of 396W on the the 12V).
Therefore, with your setup I would recommend the HD 7850. This user puts the HD 7850 MSI Twinfrozr III at 210mm long.
