Hi, I recently bought a HIS 7950 to replace my GTX650Ti, unfortunately I've had to return it as my PSU couldn't power it up due to both pci plugs sharing the same line. I cant use a molex adaptor as my lighting and fan controller are using the 2 molex plugs.
So what is the best card that I can get that only uses a single 6 or 8 pin plug. My budget is £200 I don't mind AMD or NVidia.
Current pc spec is:
CPU: i3-3240
MB: Gigabyte z77
PSU: Fractal Design, integra 650W
RAM: 2x4GB DDR3 1333MHz
GPU: GTX650Ti 1Gb (being replaced)
ETA: I only plan on a single monitor setup and have no plans to SLI/Xfire. Game that I play are tomb raider, bioshock 3, WOT, various racing sims
Current pc spec is:
CPU: i3-3240
MB: Gigabyte z77
