Best Graphics for 1024x768?
10 Feb 2007
Is it worthwhile upgrading my 7600GT to an X1950pro or 8800GTS when I only run games at 1024x768? This is for my gaming machine which is onnected to a Plasma, hence 1024x768.
or will I just be wasting my money again.....
They are all pretty intensive games which would look nicer with a better gfx card.
It's a matter of choice and budget. You seem happy enough with what you have so it's not an essential upgrade but a new card would improve things
well at such low res, your card is fine, but if you want to run them a little bit better, get the x1950pro(or better, an XT 256mb), great card for the price and you will pretty much max them games out at that res.
If you are after top image quality, max settings and aa/af and some small portion of future proofing, then a 8800gts 320 would be a good buy imo.
If you have the money to splash out, then go and get your new card, if your trying to find reasons to buy something or can't really afford it then don't bother. :)
