- 13 Jan 2004
- UK
Haven’t bought a monitor in years and looking to get a 27” gsync monitor with a limit of around £700. Any suggestions welcome. It’ll be paired with a RTX 2080 TI
With that budget why not go to 34" I had a 27" and the difference is very noticeable.
Think very carefully before getting a pure GSync monitor. Nvidia seems to be stepping away from Gsync and over to Freesync, especially as Variable Rate Refresh is part of HDMI 2.1. You're better off getting a monitor that's listed as 'Gsync compatible'.
Thanks. Might give this one a go then if the gsync compatible bit doesn’t make much difference.LG 27GL850-B
Desk space!With that budget why not go to 34" I had a 27" and the difference is very noticeable.
