- 22 Feb 2014
Hi folks!
I'm looking for a PSU that will last me a long time for an integrated graphics Haswell system that will start out needing about 200W (according to PC part picker) but will later have one, then probably two graphics cards added to it and later on will probably be overclocked. I'm looking at building a system that I'll still be using 5 years from now basically (albeit for nothing high end) by gradually adding to it over time, and as far as I've figured for this purpose a good MOBO and PSU are important. But I'm on a tight budget.
Basically I'm looking for build quality over modular, wattage over cost (to an extent, if my only best option is £60 I'll be waiting for it to come up at £55 in a sale >.<).
At the moment my choices are limited to 'Haswell ready' PSUs, but in all honesty I'm not even sure what that means. Is it vital that the PSU is Haswell ready to use a z87 mobo and Haswell CPU? What happens if I use a (decent quality) PSU that isn't Haswell certified? I've been recommended a PSU before that upon checking wasn't stated as good for Haswell.
And most importantly really, any recommendations?
Cheers for reading!
CompuChump
edit: I've looked at the CX Builder Series PSU's, but apparently they're pants despite being Corsair. Any difference between this:
Corsair Builder Series CX 500W V2 '80 Plus Bronze' Power Supply (CP-9020047-UK)
and
Corsair Builder Series CX 500w Modular '80 Plus Bronze' Power Supply (CP-9020059-UK)
worth knowing about?
I was also considering the Seasonic S12 II 520W, but it's not Haswell ready and I saw it somewhere else but can't actually find it on OC, not sure if it's going by a different name somewhere or just not here... >.<
Cheers for reading!
CompuChump
and
