- 11 Aug 2012
ordering my HD7950 but don't know which to go for as there are a good few on OC store.
Any advice on which to get?
The Sapphire Vapor-X (apparently) does not have voltage control so probably best to avoid thix.
Gigabyte Windforce X3 is highly recommended by most owners. The Sapphire Vapor-X (apparently) does not have voltage control so probably best to avoid thix.
They both have good cooling solutions, the Gigabyte perhaps running slightly cooler but not enougn to make any real difference to overclocks (due mainly to the GPU lottery). The HIS does have the bonus of having the latest turbo bios pre-installed, so maybe that might swing it. Both seem good (better than average).gigabyte have any advantages over the HIS iceQ boost?
HDMI cables seem easier to come by than mini DP - DP.
Thanks
Ordered HIS iceQ boost after reading reviews. According to the review i'v read on all 7950 cards the IceQ has the best cooling of them all? and the bonus of having the 4 free games with it.
But enjoy.i did look at the windforce but it was out of stock any way and i cant see there being that much difference between the cards anyway
