Best HDD Recovery Utility
4 Dec 2002
Bourne, Lincs
Got a HDD which I need to recover the data on, however it needs to be done with a LiveCD as its in a laptop and don't have time to get a 1.8" cable adaptor.
Any one have any suggestions for a live CD that will do the job?
Thanks
Kimbie
The system wont boot into Windows, so assuming the filesystem is damaged, will give Hiren's a look
Thanks
Kimbie
I have a 2TB Western Digital external HDD that got knocked off a desk and stopped working. I've taken the physical disk out of the enclosure and hooked it up in my system - it (very slowly) gets recognised by the BIOS and in Windows, but windows says "Not Initialised" and TestDisk says its capacity is 512b.
Does anyone know if the hirens boot cd would be suitable to attempt to get the data off?
Thanks in advance.
TestDisk is what I use. Great bit of software and free as well.
+1. Used quite a few times on friends PCs with disk crashes to save photos of their dogs/children, presentations, documents etc.
It is also included in most Linux rescue disks (e.g Parted magic, SystemrescueCD) so is easy to get running if the disk cannot be moved to another PC.
TestDisk does look extremely useful. The only problem is that it says do not use unless it detects the size of the drive correctly (which it does for all my working drives) but for the questionable one, its wrong.
