Best headphones for the iPhone?
Man of Honour
29 Jun 2004
Oxfordshire
Hey guys
I'm sick of the bad build quality of the iPhone headphones, as great as the clicker/mic is, I'm not prepared to put up with them falling apart near the base, this is the third pair
So would like a new set, ideally in ear head phones as I'm lucky to find a set of headphones that fit properly
So what are you guys using?
Don't really want to spend too much, but will do if the quality/sound makes it worth it
Cheers :)
I'd just gone for a Shure MPA-3C (Apple iPhone and Blackberry Curve) headphone adaptor. It includes a microphone and control button, should set you back about £30 leaving £20 for some reasonable headphones :)
Mine isn't here yet, but being Shure I'm expecting it to be good enough.
I did have a look at that, but was put off by the sheer amount of cable you are left with after the 1m on that, then you got the cable on the headphones themselves, would get a bit messy
Cheers for the suggestion though
Any others guys?
yet you will pay for that shure adapter and a 20 quid pair of earphones..isnt that the same as getting the new sennheisers?
i wouldnt.... cx300's are crap, that was really the point. id rather use a pair of £50 earphones and use the hadset to talk than pay £50 for those.
