Hi, my beyer DT234's which I use for pc gaming have just died on me and I'm looking to replace them with a better headset. The DT290's are within my budget,look to be better built and will hopefully give me a marked improvement over the DT234.
Has anyone had any experience of this headset and could someone confirm if these are suitable for an X-fi sound card as they're 80ohms (the dt234's are 32 ohm iirc). I've tried my Senn HD600's (300 ohms iirc) in the soundcard to see if they're driven ok and they seemed to work fine. Would the DT290's cable be terminated with two 3.5mm jacks as per the DT234's (second for the mic)or will I have to invest in a pair of 3.5mm jacks?
I loved the comfort, sound quality the dt234's gave me and I have yet to find a headset to better them (tried the medusa's and senn pc160's which were inferior imo).
If anyone knows of a headset that's better than the DT290's for <£140 could you point me in the right direction please.
Thanks
Thanks
