best i7 cooler
8 Aug 2008
glasgow, scotland
hello everyone
im waiting on my new i7 system coming and was wondering what was the best cpu cooler to get ,i want something quiet, i also heard that the 1ns with the bolts is better any help would be appreciated
regards tim
Hi m8 ,
Do you have a regards to air or a wc kit. ??
The options are the following , but i do not know how quiet they will be as these are all high performance range :
The Corsair H50 WC all in one cooler - Smallest area taken , I love mine.
The Noctua U12P - Great many like to add another fan to this for push pull config
Pro Megahalems - No fans included , so two decnet 120mm fans needed.
The TRUE Ultra - Same for this really.
McT
Hi Timaloy ,
If i am honest they are reasonably quiet. Not silent or anywhere near it. When i have my case sides on then the loudest part of my system is the case fans , PSU and graphics card fan.
However if i do take the side panel off you can hear a grumbling sound coming from the H50. This is the pump doing its thing i guess. You can hear it clearly.
There were members who bought it , heard this and then RMA'd it thinking it was faulty. I sure it was not its just not a silent system it does make noise if you get up and close and listen to it.
With this said using either of the other air options presumably with two fans in push pull configuration are not going to be much louder or quieter for that matter. Unless you get some super low profile fans or something.
McT
well mc i wint for the corsair h50 my new system is up and ruuning and its superb thanks for the info everyone imm a very happy man
Hi Timaloy ,
That is great to hear dude.
Very glad your liking it. I personally think its a really decent cooler. Cools the i7 chips well as they are very hot in general. Looks great in the case too.
Well done
McT:D
