Best i'air cooler to use with push/pull Apache's?
8 Jul 2009
So i was going to get a Corsair H50 for my new i7 build but there is so much disagreement on whether its a good cooler or not i've decided to steer clear. I definitely want to use Apache fans in push/pull (wanted to do this on the H50 too)
So which is the best to go for?
TRUE Copper?
Megahalems?
Something else?
Thanks
The H50 is a very good cooler and works even better with 2 Apache fans.
But if you want to go for air then go for the Megahalems. The TRUE copper looks nice and cools well but it is so expensive and is so heavy it should not be mounted in a tower case - which is a serious downside.
If you do go for the megahalems, make sure you get one on these fan clips as the cooler only comes with one set.
I would go for the Megahalems out of those air coolers you have listed mate.
The TRUE copper is meant to be good, but they advise not to use it on vertically mounted mobos as it can warp the board.
The Megahalems is probably the best air cooler on the go atm.
