ACF7 pro works fine on a Q6600 unless your pushing a lot of voltage through it (over 1.4-1.45ish).
It would be my choice out of all the push pin coolers... but if your serious about clocking a quad (past ~3.4gig/~1.4v) then you really want a decent bolt through.
What would be the recommended direction to mount the Sunbeam Cooler if i can. The fan facing towards the back of the case where exausts fan is or facing up the way or facing down???
I had a big problem with the Xigmatek s1283 getting the fan fitted. That anti-vibration thing is a good ideal in principle but the reality is it's almost impossible to get the fan fitted.
With the motherboard mounted inside a chassis I don't know how to get the fan mounted properly . . .
