Best iPhone 6 screen protector?
16 Feb 2010
Oxfordshire
Just wondering if anyone could recommend any that are particularly good?
I don't want anything too thick or that'll distract from the screen too much.
The anker ones look quite good and are keenly priced - has anyone tried them?
Thanks
Tech armour ballistics glass 99.9%
Tough glass saved my phone from a screen being dropped on a plug faced upwards. Just had to replace the protector.
It comes with a great application kit very easy to do and because it's glass you get no bubbles aslong as you do a ok job when cleaning. To be honest with you I sometimes forget I have the glass on. Really great addition to any phone IMO
I have Anker glass one - easy to install and doesn't change the feel of the screen.
Would be nice if it went all the way to the edge.
