Best ITX case?
12 Feb 2009
London
I currently have a Lian-li Q07B which i love but i fancy something i can stick a half decent graphics card in. I really dont wanna go too big and wanna stick with itx.
The Q08B looks ok but its not exactly that cheap and looks pretty big. I dont need a dvd drive or any internal room for drives as i only use an SSD that can be stuck anywhere.
How bad is the quality of the Sugo cases? Which would be the best to go for? Also are the psu's that come in the sugos quiet?
Leaning towards a Lian-li as really dont fancy a Sugo if its not going to be top quality. No PC-Q08 or Q11 owners around?
The PC-Q25 looks pretty decent.
The Q08 is too big IMO but the Q11 is still too small to fit a decent GPU. Pretty much you are looking at SG05/06 or 07/08. The quality is not that bad its just that obviously pressed steel just doesn't have the quality feel of the all aluminium Lian-li cases. If you go for the 450 version of the SG05/06 the PSU is pretty damned good and the one is the 07/08 is amazing. Admittedly I always change PSU fans apart from on corsair AX which have bloody amazing fans in, but the stock fans are fairly quiet.
