Best ITX Motherboad and CPU for Sub £120?
7 Oct 2003
Nottingham
My son as a Mini ITX system that he mainly uses for COD, CSS and CS-GO. Specs are currently - GA-H55N-USB3, i3 540, 4GB Memory, GTX460 and Windows 7 x64
Unfortunately either the motherboard or Cpu as started overheating, 75% sure it's the motherboard but have no way of testing. And yes it's definitely one or the other!
Anyway I have a budget of £120 to replace these with hopefully similar performing parts. It will also be a good opportunity to move from socket 1156 to the more ready available 1155.
I'm thinking the following would be best given my budget.
Intel Pentium G840 2.80GHz (Sandybridge) Socket LGA1155 Processor - Retail £56.99
MSI H61I-E35 Intel H61 (Socket 1155) DDR3 ITX Motherboard £49.99
Thoughts, Can anyone better this?
The biggest problem with that MSI board is that it doesn't have a PCI-E x16 slot, so cannot use dedicated graphic card.
I'm pretty sure it's the motherboard that's at fault. Idle temps would quickly rise to 60 and when gaming they would continue to rise and the PC would shut down after 10-20 mins.
I did try an i5 760 (known working) and it did the same thing with that. Cooling and cooler are fine and I did a ton of research and it all seemed to point towards the motherboard.
I've given up with them now and just want to replace :)
oops, didn't notice that :o
How about this one?
ASRock H61M-ITX Intel H61 (Socket 1155) DDR3 M-ITX Motherboard £59.99
Quick update.
Ordered and received today
Also got a free bag of sweeties, Thanks OcUK :D
